Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi FLE1115 won’t start
- This topic has 7 replies, 5 voices, and was last updated 14 years, 5 months ago by
cornwell40.
November 6, 2011 at 3:39 pm #66113
cornwell40
ParticipantProd number 914514505/00.
Have this machine which when you press the start button will drain for around 10 seconds then the door light flashes and it stops the programme. Diagnostics say E34 and all the test programmes work fine. Meggered and it’s all ok. I’m sure I’ve had a similar fault in the past and the pcb has been at fault. Any ideas?
TonyNovember 6, 2011 at 5:44 pm #363136Martin
ParticipantRe: Zanussi FLE1115 won’t start
My money is on the heater being duff. Though it meggers ok you say! All the same disconnect the heater leads temporarily and try running it again. 💡
November 6, 2011 at 10:34 pm #363137cornwell40
Cheers Martin. I will `give it a try. Had a few oddities recently in the megger department, stuff going down under load and perfect when initially tested.
Tony
November 8, 2011 at 10:01 pm #363138cornwell40
Tried dissing the heater…man. Didn’t change anything 🙁 .
Going in with PCB next (£75 at connect)…..here’s hoping 😥
TonyNovember 9, 2011 at 2:56 am #363139leavemetogetonwithit
It’s a long read but you may get some hints, especially towards the end.
http://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=3&t=57425&p=284035&hilit=Search{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}E2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}A6e34#p284035I’d say do a few more checks before unpackaging that board.
Mike.November 10, 2011 at 4:38 pm #363140rub
E34 is a faulty Electronic pressure switch, hopefully got you before you paid for the board
Rub
November 13, 2011 at 5:26 pm #363141keithwilliams
i was sent barking up the wrong tree with a pressure switch error code once. and yes in the end it was the heater even though it megged over 50M
November 14, 2011 at 7:28 pm #363142cornwell40
Thanks for various replies Gents. Oor Mike was closest t’was a dry joint on the board. Dontcha just love these fault codes :rolls: .
Tony
