Got a Zanussi FLE1215W which when you start any programme the following happens:
– door locks
– pump comes on
– relay clicks once on PCB
– few seconds later it resets back to the beginning of the programme.
have you been able to access the diagostic to find a fault code, could be anything, does it flash any codes (read the lights flashing down right hand side. Have had a few user boards fail.
Thanks for reply cab. No fault codes are coming up, it justs leaves the start light flashing as if prog. never started or had been paused. As I heard a click from relay I wondered if it might have triggered when motor was powered up but motor seems fine. Any help on accessing the diagnostics please?
