Zanussi FLE1215W Washer – 3 beeps but no action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FLE1215W Washer – 3 beeps but no action
  • #49028
    myfil
    I wento to a Zanussi FLE1215W Washer (PNC 914514506) today. The machine will not start (or lock the door), but when any button (except the first) is pressed it gives a code of 3 beeps.
    Changed the interlock, checked the carbons, gave up at that point until (hopefully) someone can tell me what 3 beeps indicates. (Looked thro the stickies of error codes but found nothing except EWM1000 codes. I think this one has the EWM2000 – am I right??)
    thanx chaps.
    #298547
    Re: Zanussi FLE1215W Washer – 3 beeps but no action
    you need to access diagnostics if you can to read fault code
    let me have you email will, send you some light reading
    TheSpinDoctor
    3 beeps/flashes of end of cycle LED are a pressure system circuit fault. Things to check are: Mechanical/analogic pressostats, air chamber & air hoses, sump hose, drain filter, wash heater, main board, wiring to all electrical components I have just listed.
    EWM1000 & EWM2000 fault codes are more or less the same.
