Gotta go out to a Zanussi FLE1216W, which is skipping programme & going to end of programme & spin led flashing, customer says when she selects spin only it will spin, she has cleaned filter & water is getting away, any ideas or pointers would be gratefully recieved.
I’ve changed tacgo magnet & new brushes, also cleaned armature, still causing problems, on test if i select spin only,after start (sometimes) you hear door lock, pump starts, hear relay click no motor action, then start led flashes. Tried most prog’s this happens.
