ZANUSSI FLE1416W prog locking out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ZANUSSI FLE1416W prog locking out
  • #61135
    alro
    Hi gents
    fle1416w select a wash programme fills washes for a while machine stops locks out 2&3 &5 neon lite on right hand side with start/ reset flashing does anyone know code as i can not work it out this machine has no display window switch machine off back on and select spin finishes programme
    cheers alro
    #344976
    TheSpinDoctor
    Re: ZANUSSI FLE1416W prog locking out
    When you say 2,3 & 5 are you counting top to bottom or bottom to top? If Bottom to top it is E61 which is most likely a duff heater.
    #344977
    E61 can also be htr relay on board.
    Mike.
    #344978
    alro
    cheers for imfo counting top as 1
    so its 23&5 from top to bottom
    alro
    #344979
    Don’t know how to get fault code from that but whenever one of these stops mid cycle I’m looking for an insulation fault (<40M) around heater.
    Mike.
