Re: Zanussi FLS1183W How to remove & fit Pump
Dave_Conway wrote:There will be three screws securing the pump motor to the filter housing, torx or pozidrive normally.
If it’s goosed, you can just replace it with a universal type magnetic pump from the shop@.
Hopefully though it will just be a restiction in there.
To add to Daves post,
Drain all water form machine and lie it on its left side, the pump will then be (base facing you) at the top left, u will find it easier that way.
In any case always pull the plug :zap:
Reegards Greg
