Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi FLS1186W
- This topic has 9 replies, 4 voices, and was last updated 18 years, 2 months ago by
RickT.
January 25, 2008 at 3:51 pm #34061
RickT
ParticipantHi,
Strange fault with this one! Machine has intermittent power supply to hot fill solenoid. Set machine to any wash cycle, starts to fill (approx 5-10 secs) then stops (no power to solenoid) . After approx 15 seconds solenoid kicks in again for a few more seconds then stops. This happens about 3-4 times until it stops altogether. There are no timer or pressure switch clicks as this is happening. Have checked solenoids ok. The common supply to both valves runs across the timer board down to the module. Thinking it might be an iffy triac on the module . No clues on the tds software. Has anyone come across this ?
Cheers RickJanuary 25, 2008 at 4:26 pm #241075Martin
ParticipantRe: Zanussi FLS1186W
Does the fill process work OK on the rinses I wonder?
January 25, 2008 at 4:31 pm #241076RickT
It did at the first attempt but then no joy.
January 25, 2008 at 4:37 pm #241077Martin
RickT wrote:It did at the first attempt but then no joy.
Mmmmmm?? :hmm:
Makes me think that it may be pressure switch problem in spite of you not noticing any clicking going on (i.e bad contact?)?
I guess the heater checks out OK and the water level system (manifold) is clear?
January 25, 2008 at 4:48 pm #241078RickT
Thanks for the help Martin .Have checked all mentioned and ok. Have checked EMW and they state filling problems with this module. Do you know if the 546 546 and 546 547 modules are interchangable as I have the latter in my old stock.
RickJanuary 25, 2008 at 4:50 pm #241079Martin
Dunno mate?…sorry 😕
All the best with it! 😀
January 25, 2008 at 5:08 pm #241080PGS
I had this years ago with a hoover logic, what was happening was when coil warmed up it went open circuit and when cool would fill for a few seconds and on and on worth a try, let us know .Paul.
January 25, 2008 at 7:32 pm #241081RickT
I’ve had that few times over the years as well and did fit a new solenoid to rule it out. In this case though the actual power supply to the valve is failing.
RickJanuary 25, 2008 at 11:41 pm #241082aqualectric
546546 and 546547 are different. These boards are full computer PCBs and I would suspect the board over the pressure switch. I don’t recall ever having to change a pressure switch on a modern Zanussi type machine; at least I never cleared a fault by doing so.
Get a board from EMW – lowest cost (and risk) solution. 😉HTH,
Steve.
January 26, 2008 at 9:40 am #241083RickT
Thanks Steve , you’ve confirmed my suspicions.
Cheers Rick -
