Zanussi FLS1383W motor problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FLS1383W motor problem
  • #13345
    stratfordgirl
    Hi, I’m a newcomer here (and relatively new to the trade), and wonder if anyone can help with a problem on a Zanussi FLS1383W (5 years old, hybrid timer/PCB setup, not heavily used). On wash, the drum fills to correct level and then stops – motor doesn’t turn. On spin, it just drains continuously – no spin.
    The motor brushes appear original and less than half worn. I’ve checked all the resistance values across all motor terminals against the service manual – all OK. No insulation breakdown either. I’ve fitted a new PCB, as a couple of joints looked slightly overheated – fault remains. The timer motor resistance appears OK too. Any ideas, please?
    #154335
    Re: Zanussi FLS1383W motor problem
    The motor is controlled by the PCB, as is the timer advance. It more or less has to be the board. Assuming the wiring to be intact of course. There are two different versions of this machine, so pnc code needed. EMW or QER will supply reconditioned units, a cheaper option if there is any doubt about the diagnosis.
    If you’ve fitted a brand new timer/pcb then the chances of that being faulty are not great ❗
    This leaves wiring between pcb and motor. Check continuity from pcb right down through motor circuit. It should be easy enough to follow the wiring up from the motor to the pcb. If all seems well, try wiggling the wires about, especially at connectors, then check again.
    Mike.
    You certainly had a really bad day. Don’t worry it’ll all pass. 🙂
    #154337
    stratfordgirl
    Thanks for the tips, and reassurance. I took the part number for the module 1247052218 – from the Distriparts DVD, using the PNC from the machine – 91478057800. I’ve now printed off the circuit diagrams and will trace the continuity through the circuit as you suggest. I’ll post the outcome when I’ve solved it.
    #154338
    wilf
    what motor have you got ce set is no bother but if its a sole check that the tacho magnet hasnt come loose
    wilf
    #154339
    megawatt
    I had a similar problem on a Zanussi some time ago. I too checked the motor and then moved on. In the end it turned out to be the motor even though all coils had continunity. Try slaving in a second hand motor as a test.
    #154340
    If you’d like a second hand Sole motor, I’ve got a couple and maybe a Ceset. £15 each + post at cost(about a tenner). They’re smallish though,
    so would need to know label details and dimensions.
    Mike.
    #154341
    stratfordgirl
    I solved this eventually last Friday. Turned out to be a fault in one of the fast cam switches in the timer. I only found this out by substituting a new timer. Motor, pcb and wiring were fine.
    #154342
    So in fact you had been supplied with a faulty new timer 😕
    Mike.
    #154343
    It is annoying when you think you have eliminated something and it turns out the new part is faulty. I was asked to look at a central heating problem the other day. The hot water was getting too hot and the customer got a sparky to fit a new cylinder stat. This made no difference so he called me in to do a proper diagnosis. After continuity checks and functional tests I concluded that the new stat. was also faulty. 😯 I fitted another new one and that did the trick.
    #154344
    stratfordgirl
    No, I had replaced the PCB only on my first attempt, not the timer. When I went back equipped with new motor, PCB and timer, only the new timer was needed. The old motor and PCB are back in the machine and working fine.
    #154345
    Sorry, when you called it a hybrid timer/pcb I assumed you meant the module was fixed to the timer. I just looked up the parts and now see that is not the case. 💡
