Zanussi fridge freezer
  • #8252
    Panther
    Hi all,
    Dave’s daughter here hope you can help me im new to this so bear with me….. 😳
    Has anyone come across a zanussi ZX79/5SI F/F with ice build up on the air return drain to the freezer? All other functions are working fine eg; defrost cycles fine thermostat fine and its had a new pcb fitted very recently. The only way the we can solve the problem is to defrost the appliance completely but it happens again within a few weeks. We cannot figure out what could be causing this problem.
    Any help would be great
    Thanx alot chaps
    Mandi
    #127651
    johnboy
    Problem is due to faulty sensors (part no. 2147168013) quite a common problem. An alternative supplier was sort by Zannusi so they will be slightly different to the original in appearance.
    #127652
    Panther
    Re: Zanussi fridge freezer
    Thank you, much apreciated. 😆
