Zanussi Fridge Freezer
  • #25732
    DentedPorsche
    Hiyas,
    Can anyone send me a wiring diagram for this machine?
    I’ve inherited the job, runs ok, defrost timer switches off and it never switches on again. (Has had 3 engineers to it and new defrost timer was fitted, wiring mixed up?)
    Any ideas on the likely cause if it’s not a wiring mix up?
    Product number is 925887663-02
    Brian
    #207372
    helo_75
    Re: Zanussi Fridge Freezer
    is it an invensys or a sankyo timer ive had this , and i needed to rewire it
    #207373
    DentedPorsche
    It’s the Sankyo timer, same as originally fitted, I’m led to believe.
    #207374
    farmboy
    There should be a small wiring diagram on the side of the timer, neutral for the timer motor, a live common feed, normally closed to the compressor/stat and normally open to the defrost system. (except during the defrost phase obviously)
    It sounds like the common live & supply to compressor are reversed, quick check with a multimeter will confirm.
    #207375
    cab
    THE PRODUCT NUMBER DOESNT GO INTO TDS
    CAB
    #207376
    DentedPorsche
    Nor on mine, although mine is 3 years old.
    Offhand can’t remember the model number, something like zfc (or zcf) 55/4i
    Brian
    #207377
    cab
    you have mail.
    cab
    #207378
    DentedPorsche
    Thanks Cab, the information is spot on.
    Brian 😀
    #207379
    DentedPorsche
    Thanks for the wiring diagrams Cab, problem sorted now.
    Brian
    #207380
    cab
    glad to be of assistance 😀
    cab
