Zanussi Fridge/freezer door problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi Fridge/freezer door problem
  • #9356
    I have a problem with my Zanussi fridge/freezer. The fridge door has dropped slightly which means that the fridge light is permanently on. Also the door no longer seals properly. It is still useable but only temporarily. Can you tell me what the problem is likely to be and where I can get parts if required please.
    #133681
    Dave_Conway
    Re: Zanussi Fridge/freezer door problem
    Model number please Debbie.
    #133682
    Sorry – meant to include it in the subject 😳
    It’s a ZFK 56/48R
    #133683
    Weirdjam
    You can buy the door seal and replace yourself or get an engineer to change it.(For your fridge/freezer the fridge door seal is available)
    Dave should help with the part I imagine.
    As for the door dropping sometimes caused by age, over time the cabinet starts to twist and pulls the door down with it, its very hard to reverse this process just make sure it is completly level. A few washers on the bottom hinge of the door will raise the door enough to turn off the light.
    ***Remember to switch off the fridge before you work on it!***
    HTH
    #133684
    Thanks – I’ll give this a try
