Zanussi Fridge-Freezer Fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi Fridge-Freezer Fault
  • #33302
    hammered
    I have a Zanussi ZX99 which is about 2 years old. The fridge got warm so I followed the advice to check the freezer heat exchanger which was iced up. After defrosting the fridge works again for about a week until the heat exchanger starts to ice up under the two ports that take cold air to the fridge. (but the centre area is clear of ice).
    Is this a simple repair or should I scrap it?
    #238211
    Dales-Electronic
    Re: Zanussi Fridge-Freezer Fault
    Could you give me the PNC number please there are many zx99 versions.
    #238212
    hammered
    NP PRO 928405946-02, Model /ZX99/5W
    #238213
    Dales-Electronic
    Working upon what you have described I would suggest you have a problem with the defrost heater. Either this is duff or you have a problem with the defrost timer which is not supplying the power to the heater.
    #238214
    Alex
    No timer on these, all controlled by electronic modules with sensors.
    Suspect the sensors may be at fault.
    Alex
