zanussi fridge freezer zx97/5
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum zanussi fridge freezer zx97/5
  • #78313
    gaspurge747
    where could I get wiring diagram for this appliance. Also how do I get to defrost stat, freezer works fridge does not.
    #405193
    Seamy
    Re: zanussi fridge freezer zx97/5
    Wiring diagrams can’t be supplied to the general public, see forum rules.
    Would advise that the problem you describe of freezer working but fridge not sounds like the evaporator battery in freezer is blocked up with frost & no cold air can be circulated up to fridge by the fan in freezer section.
    Advise you to totally defrost the appliance for 24-48 hours & try to run it again.
    If it cools in fridge after this defrosting, i’d be looking at the defrosting being the problem.
    #405194
    gaspurge747
    thank you for that information will do as you said.
    #405195
    gaspurge747
    found problem door seal on fridge door, could please tell me is this a easy job to do, thank you
    #405196
    Seamy
    Quite easy to replace door seal if its the replaceable type, theres a part number for a seal 2144830029 but would need 9 digit product code plus /01/02/03 etc to confirm its the correct one.
    Not quite sure how this would effect the freezer to work but not the fridge though.
    #405197
    Andy jones
    Agree. Can’t see how seal would stop fridge working ?
    #405198
    Seamy
    Would again recommend that you check evaporator fan in freezer section & possibly the condenser fan at rear bottom beside compressor if either are seized or have slowed up you would get poor cooling in fridge & possibly build up of frost in freezer.
