Re: zanussi fridge freezer ZX99551
bigchrisoioi wrote:before u do that check the following…these fridges can be complex!
defrost heaters > may have 2 !
fan is running
evaporater is not blocked wih ice
if temps all over the place the ntc sensors can be badly out of calibration
remove plinths and clean condensor as it sits underneath fridge
check compressor temp and make sure compressor cooling fan is ok
hope this helps, chris
Thanks for that! ….Customer is currently mulling over the quoted cost of a module . I will report back, I may have the thing back in the workshop to strip down
Thanks again 😀
