Zanussi frost free f/freezer ZX56/4SI
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi frost free f/freezer ZX56/4SI
  • #21781
    DAR01
    Customer says fridge doesn’t appear to get as cool as it should.
    Checked duct from freezer to fridge seems clear.
    When freezer door open cool air seems to flow OK into fridge.
    Evaporator seems normal.
    Any ideas please.
    Mike 🙁 🙁 🙁
    #192486
    cab
    Re: Zanussi frost free f/freezer ZX56/4SI
    Hi have had a look on tds disc not much on there, but I have a feeling that there was a bulletin about a colder running stat, anyone else recall anything?
    cab
    #192487
    bassman
    Hi I’m not sure if it applies to this model but I’ve found a few of these where the duct in the freezer freezes over if the fridge door is left open to check you need to lift the freezer evaporator away from the freezer back wall as the duct is hidden behind the evaporator .
    Hope this helps.
    #192488
    DAR01
    Duct is above fan on this one, evaporator looks normal.
    Mike 🙁 🙁 🙁
    #192489
    abbots
    are you sure there isn’t a duct behind the evaporator as well?
    i thought the duct above the fan fed the top duct in the fridge and the duct behind the evaporator at the bottom fed the bottom duct in the fridge behind the salad crisper on the right.
    john
    #192490
    agro
    I’ve had a couple off these i think definetly check the ducting if its blocked will be the defrost timer
    #192491
    DAR01
    Thanks for that info, didn’t realise there was another vent.
    Turns out there was a block of cheese blocking the vent.
    Glad I was able to solve the problem with your help, I’ll know next time.
    Many Thanks,
    Mike 😳 😳 😳
