Zanussi Frost Frost Free Fridge / Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi Frost Frost Free Fridge / Freezer
  • #33058
    johnuk
    Hi All
    I have just moved home and transported the fridge / Freezer layng down
    what I didn,t know was that you are supposed to leave them off for 24 hrs , anyhow it worked for a day or so then the fridge stopped working , I was advised to turn it off for 24 hrs which I did and it worked for 2 days , turned it off again for 36 hours and it worked for a week , now it has gone again , I can here a clicking noise which was not there when it worked for a week ? basiccly do I need to replace it its a year old or can it be repaired, any help would be very much appreciated
    have a great xmas and thanks
    I have just had a look on the sticky fridge freezer problems
    I presume the compressor may be faulty or I have a blockage
    would it be cheaper to have repaired than buy a new one
    Thanks again
    #237284
    helo_75
    oooh, tricky one
    the clicking could be the compressor overworking, and its very possible the machine is now blocked and the compressors failing under an exceptionally heavy load
    sometimes, if your lucky, blockages can be cleared, but your going to at least need a new dryer and a regas
    experience would suggest replacement is the best option
    #237285
    johnuk
    Re: Zanussi Frost Frost Free Fridge / Freezer
    thankyou for your reply
    strange how it worked perfectly for a week
    anyhow a replacement it is
    #237286
    helo_75
    they have a nasty habit of doin that, it does sometimes take time for the for the oil to mix and reduce the flow of gas
    sorry to have to do that to ya, but you may have thrown money away on a repair that MIGHT have worked
    #237287
    johnuk
    Hi Again
    Just an update Fridge and freezer seem to be working fine the freezer is at minus 18 and the fridge at around 4 , the tempreture dial i have turned down to between 2 and 3 but i have noticed appliance does not turn off and on would that be a thermostat problem , if i turn the dial lower then machine will turn off then come back on after about 10 mins . i still appear to be getting this clicking noise , does the appliance need to be turning its self off and on during the day ? any help again i would be grateful
