Zanussi fs1255w
  • #36102
    allan
    Hi all, been to a Zanussi fs1255w, fault is would not start, when you pressed start button door switch clunked about three times then nothing, changed door switch same thing, took out facia control module and found damaged tracks where connector from door lock was. sent module off to qer, fitted repaired module today and nothing at all not even clunking door lock, checked edge connectors but all ok, door lock light flashes 5 times apart from that nothing at all, wonder if the repair to the module was ok? customer willing to have new module, not sure I want to get stuck with it if it still not work, am i missing anything else?
    Thanks Allan
    #249516
    boselecta
    Re: Zanussi fs1255w
    when you fitted the new module did you check for error codes when it didnt work?
    #249517
    allan
    Re: Zanussi fs1255w
    all it does is door lock light flashes 5 times then delay then 5 flashes and so on, cant get it to do anything else, i see there are two modules listed for this one says preconfigured ewm1000 but suitable for this model much dearer too?
    #249518
    allan
    Re: Zanussi fs1255w
    Sorry its the end light that flashes 5 times not the door lock light, Doh 😳 😳
    #249519
    Flyman
    Re: Zanussi fs1255w
    End light flashing 5 times is showing a motor related fault. Enter the diagnostics for the actual fault code. Is this the same fs1255w that you have a post running about trying to configure a new module? 😕
    #249520
    allan
    Re: Zanussi fs1255w
    Yes it is, original board had blown tracks where the door lock edge connector joins, similar to hotpoint wma series, sent board of to qer for repair but still no joy so assumed board repair was unsuccesful, machine will do nothing, door wont lock just the flashing end light, could motor fault have blown module instead of door lock? and would a fault with the motor cause it to do nothing now?
    Thanks Allan
