Zanussi FS1255W
  • #68535
    folleyball
    Went to this washer today.
    Whatever programme you select the pump runs for a couple of seconds then nothing.
    Did a diagnostic test. The left light flashed 4 times the right 5.
    Wasn’t sure if that was E41 or E45 but both errors point to the door interlock. I tried changing the interlock but the same problem occured.
    Anbody come accross this problem?
    #371448
    Re: Zanussi FS1255W
    If there was an issue with the interlock then the door wouldn’t lock and the programme wouldn’t start. Beyond that, a careful check of motor and heater a priority I reckon. 🙂
    #371449
    Re: Zanussi FS1255W
    1st things to try:- Either damp – condensation on plastic brush holders (what’s weather been like where you are lately?), or motor or element below 40 megohm IR.
    Mike.
