Zanussi fs1255w Module
  • #36127
    allan
    Hi can anyone please tell me what the difference is, on connects site there are two different modules listed for the Zanussi fs1255w one is preconfigured and about £40 more? I have ordered the cheaper one and think i may have made a cock up!
    Thanks Allan
    #249664
    boselecta
    Re: Zanussi fs1255w Module
    One is the pre-configured, the other you have to configure yourself using binary coding, can be quite trickey to do. Did a day course on coding these modules from blank at last place of work, I would advise getting the pre-configured board. i have the config codes if you are going to do it yourself.
    what is the pnc?, its easier to do on machines that have an led display.
    #249665
    allan
    hi that would help a lot thanks, i have already got new board so will have to try and program it 😥 I think the pcn is 914791166 serial no. 32100949 type p6847646
    Thanks again, look for ward to receiving the codes
    Allan
    #249666
    boselecta
    will post it tomoro when back in the office
    #249667
    allan
    Cheers mate
    #249668
    helo_75
    its written on the pcb
    on the white label on the top
    good luck
    #249669
    boselecta
    Sorry to get your hopes up havn’t got his config code, too late model. you will need a pre-configured board as these blank ones reply on you having the code. try electrolux tech to get the code.
    The code wont be on the top of a blank board.
    #249670
    allan
    Thanks for your help and time
    Allan
    #249671
    Seamy
    As Helo stated, code for new board will have to be copied off old one and new board then configured, theres a white sticker on old board with the code written on it.
    Its not that easy to do if you haven’t done it before.
    #249672
    DentedPorsche
    Can you program the EWM1000 boards? There are no instructions in the service manual for it (that I can see) and if I remember correctly there isn’t a code sticker on the old module either.
    There’s no code on my TDS disc and there’s no code on Pro Corner either.
    I’m interested in this one as I’ve always been given pre configured boards.
    Brian
    #249673
    allan
    Thanks, how can you enter the code and then configure the board?
    Thanks Allan
    #249674
    helo_75
    ahhhh, nope,you cant configure ewm1000 pcb’s
    u need a configured on for that, im afraid
    #249675
    Seamy
    132120226 or 1324017209 are listed as non configured boards for this machine.
    97391479116607 is the configured board.
    Electrolux now only supply the configured type, presume other suppliers still have old stocks of non configured boards.
    Not sure how to configure this board type but as far as i’m aware all new boards have a serial interface connection point (J7 on this board) & in future Service Force engineers will be able to reconfigure all boards using a laptop and SideKick software.
