Hi we have a Zanussi FX 1465w prod no 91479270500. When you start req’d program it will take water for split second then stop if you select drain it will drain for split second then stop.When it stops the light’s are all as normal as if the machine was functioning ok. Thanks in advance
Check components for short to earth, heater & motor in particular. Check connections to components especially the pressure switch & door switch. Does any error code come up when it shuts down, does start l.e.d flash? And if so how many times.
