Zanussi FX1265W Washer
  • #31796
    cornflakes
    Client has just returned from holiday, loaded machine..nothing occured
    found 13amp fuse HAD blown although machine had been idle for a week
    unit just flashing end neon 4 pulses, pause 4 pulse
    i have change door interlock
    same problems
    thanks for any ideas
    graham
    Leicestershire
    #232533
    Re: Zanussi FX1265W Washer
    Whilst the 4 flashes is to do with an interlock or pcb problem. I can’t help thinking that perhaps the last time the machine was used the motor went belly up during the final spin and took out the fuse?….maybe??
    #232534
    cab
    44 code is pcb fault.
    cab
    #232535
    cornflakes
    any idea of ball park cost of PCB?
    bearing in mindyou can get washer for less than £200 in my location at Makro..be it Hotpoint is the downside
    #232536
    Bryan
    QER or EMW will repair PCB for around £30+vat :idea:.
    Of course you’ll need to be sure of the reason the PCB failed.
    HTH
    Bryan
