Zanussi Washer FX1465W 91479270500 all vertical LED flash twice
Customer says it does not empty or spin but when I tried it full of water and spun it out worked ok, only all the 5 vertical LED to the left of the spin selector flash twice pause then it is repeated, machine still empted and spun.
Could not find fault code for this in the Known error codes
I did check to see if there was a blocked pressure bottle that was clean.
Any suggestions will be much appreciated
Bernie
