machine flashes 4 times(door open fault) replaced interlock, still same 😥 will it be the control module blown ❓ anybody had this fault ❓ is it possibly like when the wma door locks blow,they take out the board ❓ ❓
deltra wrote: anybody had this fault ❓ is it possibly like when the wma door locks blow,they take out the board ❓ ❓
Yes , I`ve certainly had faulty door interlock on this model blowing tracks on the PCB and managed to repair damage with a couple of link wires and soldering iron more like on the Hotpoint WM rather than the WMA :wink:.
Slightly awkward to remove module but it should be worth the effort.
Have one of these where lock has gone and blown 2 tracks on board near selector switch. There are three identical surface mounted devices in series with one of the blown tracks. Each device bears the number “154”.
Two of them measure about 150Kohms but the one nearest to the blown track will not give a reading. Are these resistors? Could I use an ordinary resistor in place of an smd if I can make it fit?
Ah, just noticed other smd’s on component side with same numbers and labelled R-this and R-that so think that’s my answer.
However, all “154”‘s on other parts of the board measure around 132Kohms not 150 😕
Anyone know if the figure is a value or some kind of code?
Mike.
