Zanussi FX1465W with issues.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FX1465W with issues.
  • #24509
    aqualectric
    Zanussi FX1465W Prod no. 914792705/00. Serial no. 342.
    Press the ‘on’ button. Only the ‘End’ LED is lit; machine beeps 5 times. No start / pause LED. No door locked lamp either. Machine otherwise dead. Power to the door interlock – tried a new one – no difference. No programming possible. 😕
    I am pretty sure it’s the computer unit – removed it and there were no blown tracks or joints.
    Any thoughts?
    Thanks,
    Steve.
    #202343
    cab
    Re: Zanussi FX1465W with issues.
    FLASHING FIVE TIMES INDICATES E50 FAULT (MOTOR RELATED) GOING INTO DIAGNOSTICS WILL GIVE YOU THE EXACT CODE AND COMPONENT FAILED.
    iF YOU NEED HELP WITH DIAGNOSTIC LET ME KNOW VIA PM.
    CAB
    #202344
    Tony_EMW
    Send it to us for test ! (common faults are interlock short or shorting/melting pump). Tony EMW
