Zanussi grill loose.
  • #34999
    Model ZHF865 W/B/X
    Don’t have PNC number.
    Not the first time I have seen this but the last one scrapped the oven.
    The grill securing bolt 311609006 has corroded away allowing the hinged grill element to drop down. Is there a fix or workaround to support this grill or is this another BER. 😥
    Bryan
    Re: Zanussi grill loose.
    Hi Jim
    Part No. 3113609006 is a replacement grill pin, from memory you need to remove the top and fix it with a nut.
    HTH
    Bryan
    #244731
    robbo1973
    i think in the past i have used a dry lining wall plug toggle type with 2 legs which splay apart.
    chris.
    #244732
    rogue_element
    hi jim
    please try this part number 50223152005
    rogue
    #244733
    Thanks for replies, the threaded part of the old one is still in there. Is it possible to drill it out from the top to refit. ❓
    Bryan
    Again, from memory the original one is rivitted in place and I don’t think it even needed drilled out. The new thinner threaded shaft slotted into place and fixed with a nut.
    The job was a doddle anyway and although those double built under ovens look difficult to remove from their housing, they’re no problem really.
    Bryan
    #244735
    rogue_element
    hi jim
    the one we us just need drilling in to cavity. no need to pull oven out
    rogue
    #244736
    I did have a close look inside and the hole appears to be blocked with the remains of the previous stud.
    Will report back once I have sorted it.
