Mod ZT685 Prod 911847004 Ser81700101
This machine will fill with water (although it seems to do it slowly)and then it will stop with the rinse hold light flashing.
Sometimes it will fill and wash and then when it drains and starts to fill again it will stop again with the rinse hold light flashing.Now, in the manual it says the rinse hold light flashing is a water inlet problem, so i guess its not filling in time alowed. Ive cleaned all the pipes and tubes from the inlet water break system to sump which were a bit gunged up. But it still has the same problem. The water break system seems quite clean from what i can see and the water pressure is ok.
Will changing the water break system cure this problem or is it something else.
let the machine start and wait till it starts to fill
open door and add a bucket of water if its a slow fill fault ie valve failure it should start to work when water get to correct level
If it’s the type that when the filter is removed and there is a hidden chamber under the sump accessed by a small gap in the base of the sump. It is worth fishing around in there as in the past I have removed chunks of food, cling film etc which created fill problems – I think it is connected to the air gap chamber system.
