Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi IZ 141 S
- This topic has 9 replies, 3 voices, and was last updated 13 years, 9 months ago by
newgas.
July 5, 2012 at 8:21 pm #70325
newgas
ParticipantThe door is locked and won’t open with the washing inside and it does’nt start up as it normally does, and it shows ‘err’ code comes up followed by 3 dashes with a few bleeps, what could it be ?
I have looked in the book but it says it requires reset but even pressing reset gives the same code .
I hope someone can help!TIA
July 6, 2012 at 7:11 am #377796Allsorts
ParticipantRe: Zanussi IZ 141 S
If there is water in the machine then the water may prevent the door from opening. Is there any water in the machine?
If so drain the water by means of lowering the drain-hose to floor level, or, open the filter. (beware of the water if opening the filter).
July 6, 2012 at 3:26 pm #377797newgas
Hi , there is no water in the machine and I have drained the water that was in the filter and the little hose next to it , still no change the door is locked and the machine does’nt respond to anything.
Thanks for the reply.July 6, 2012 at 9:27 pm #377798slyp98
is there a code number on the display ? if not it is possibly the door interlock , engineer required for this im afraid as it could be a control board prob also
July 7, 2012 at 2:07 pm #377799newgas
I have taken door interlock out and it maybe getting stuck or as you say maybe getting volts problem from pcb.
can new pcb go straight in if it is that or does it need Manu. engineer to code it to appliance.July 7, 2012 at 5:26 pm #377800slyp98
nah no need for engineer to code it but if it has blown the tracks and components associated with the lock , its a new or recond board im afraid only one way to find out get the new lock in there
July 8, 2012 at 3:34 am #377801newgas
Tried the switch from mums machine and hey presto, apparently the switch is know to take out the pcb, so I was told by a repairman
Thanks all the same, seems like a good forum.July 8, 2012 at 10:20 am #377802slyp98
result !!
July 9, 2012 at 4:58 pm #377803newgas
Have just ordred the part from ebay for 15.50 inc. 1st class delivery.
Not bad.
Thanks slyp98
July 17, 2012 at 8:35 pm #377804slyp98
no hassle , keep this site handy
