zanussi iz12 stopping mid cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi iz12 stopping mid cycle
  • #64832
    slyp98
    hi again busy this week lads , have this recurring problem, i replaced the motor brushes ran fine for 3 weeks now prob is back again anyone have tech info on these thanks k
    #358229
    clockworkone
    Re: zanussi iz12 stopping mid cycle
    email address.
    #358230
    slyp98
    Iran a diagnostic on this and returned E34 , problem between the mechanical pressure switch and the anti boil switch , on closer inspection of the board i see this , looks nasty but its just surface , would this suggest more hidden problems or will a problem with the switches cause it , i see its burnt in the power supply area of the board according to the tech sheet (thanks dave ).
    #358231
    ANDYVIVO
    Check the pressure hoses for any wear. Have had this before on my IZ16. Air leaks through either of the hoses causes the cycle to abort.
    Regards Andy
    #358232
    slyp98
    cheers Andy i checked both hoses no wear all fine , and mechanical pressure switch seems fine also , so i’m puttin in a new analogic switch
    #358233
    slyp98
    this fault weas cured by installing a new analog switch
