Zanussi IZ141 anomaly
  • #78934
    robstech
    I have just completed a bearing and shaft replacement on a IZ141, on testing on spin cycle the machine takes in water whilst pumping and spinning, no error codes coming up. It does however complete a wash cycle with no apparent problem. How do you access the self disgnostics on this machine?
    Any help appreciated
    Robert
    #407423
    Re: Zanussi IZ141 anomaly
    Press and hold in the Start and the Skip button then turn on the On/off switch. To read of the last error detected you have to press the Fabrics or Temp button until the no9 LED lights.
    Though from what you tell us I don’t think this will help you. It’s possible you could have got water in the works or damaged a wire whilst doing the bearing job, do you think?
    #407424
    Seamy
    Check for chaffing of cable loom, damage to cables going to valves, pump, motor etc, sounds like there may have been a cable nicked or something. Check heater, motor for earth leakage also.
    #407425
    robstech
    Thank you both,
    checked heater,cables and ntc terminals, brushed off some carbon deposit from the module and everything is working normal now. ❗
    Rob
