Called at a Zan IZ16 (91451300500), when you press start the door locks then the wash, rinse and spin lights come on, no further progress. No fault code is displayed. Having looked at the manual i am not sure if this is a binary fault code or the programme board playing up. Anyone had the same?
Thanks for any advice
Graeme
Chris, it says “Your Inbox is 0{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} full”??
please send to geservices@supanet if there is a problem.
Thanks, Graeme
Sorry to bounce this Chris.
I have no file, tried to PM you but the mail is stuck in the outbox.
Have you a problem wih the PM service?
If you could post anyhing to geservices@supanet or give me a brief rundown of the content it would be appreciated.
Graeme
Thanks to Cliff and Chris, will have to change my email account, has a 5mb attachment limit, a bit mean.
If i read this correct i have E38 “pressure chamber blocked”.
Obviously will return to check Monday. The fault table says E38 does not stop the programme, heat phase skipped. Anyone know otherwise?
