Zanussi IZ161W Fault?
  • #15749
    Kirk
    I have a customer that the user interface was changed, customer now complaining it sticks on 49 mins for about 10 min, this as far as I know is it heating but she her husband and father won’t have it probably a teacher,
    we have been back twice waited for it to heat and carry on all fine they say it works but should not stop on the time as it says only 49 mins and should take 49 mins. Help! she has no hand book and I don’t know if it explains it ?
    Kirk
    #166173
    Re: Zanussi IZ161W Fault?
    Kirk wrote:Help! she has no hand book and I don’t know if it explains it ?
    Download the user manual you need here:-
    http://www.electrolux-ui.com:8080/master.nsf/SearchFrame?OpenFrameSet
    #166174
    Kirk
    Thanks Martin for the quick reply but I can’t find this one.
    IZ161W 40501504 / 91451309700
    Thanks Kirk
    #166175
    Dave_Conway
    Put the PNC 914513097 (without the two zeros) in with no other info, it finds it then 🙂
    #166176
    Kirk
    Thanks Dave got it but it still does not tell me if I’am correct or not
    small print explaining it adjusts itself, but customer wont believe it.
    Kirk
    #166177
    I’m fairly sure that if the machine was at fault at all, then it would display an error code of that fault. The fact that the machine eventually completes the cycle is proof enough it works OK. 😉
    Having said that, I cannot fathom why the display would ‘pause’ at the same time for around 10 mins though…very odd ❗
    Have you looked at the sequence chart and checked on the programme timings I wonder? The TDS disk gives a few examples as a guide for you 🙂
