My Zan IZ16s washing machine is making a very strange noise from the lower front right hand side. Coupled with this is that it appears not to be draining properly. It will drain but only if the outlet pipe is at the height of the bottom of the door.My thought is that the drain pump has packed in or could it be blocked?. Everything else appears ok, its filling, spinning etc. Would any member agree.
Is a pump change is difficult job?
