zanussi Jet Sustem- ZWD1472S Washer / Dryer – not Drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi Jet Sustem- ZWD1472S Washer / Dryer – not Drying
  • #77254
    Whiteley26
    Good afternoon,
    I have the above washer / dryer and I trend to use the dryer option today and the machine does not get warm, it counts down and the drum turns but no heat, the machine is nearly 5 years old and I have only used the dryer function a handful of times that last maybe a year ago.
    Any help is gratefully received
    Regards
    Tina
    #401552
    Re: zanussi Jet Sustem- ZWD1472S Washer / Dryer – not Drying
    Dryer heater element decays through lack of use. Though the fault may also be the thermal trip located on the main dryer duct.
    #401553
    Whiteley26
    Would this be something that is fixable at home or is an engineer needed?
    #401554
    Well an engineer could certainly fix it for you of course. However if you have sufficient electrical knowledge, the right tools and test equipment it would also be possible to sort it yourself. Your choice. 😉
