my machine came up with error E20 after stopping on the rinse cycle leaving the drum full of water
I drained the drum and pulled the filter out not much in there I also checked the bushes , loads left on them , I cleaned the armature up as it was a bit black.
I took the pump off and checked that, there was nothing inside it, I wired it up direct and is started pulsing, so guess its working
got it all back together and now all that happens if I start a cycle is it locks the door sounds like the pump kicks in and nothing, not even if I change the programme etc , nothing happens at all
Any ideas please.
