Zanussi Jetsystem starting to fail
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Jetsystem starting to fail
  • #54669
    BigAlly
    Hi guys,
    Our 8 year old washer dryer (WJD1357S) has started to play up, last week, a couple of times it has not hit top speed on the spin cycle, and yesterday when spinning some towels it sounded like a couple of cricket balls where being spun as well – a sort of clunking sound and when the cycle finished the missus said the machine was smoking slightly!.
    I’ve had a look and the main door seal has a inner plastic lip that has degraded badly and deposited loads of “chewed” bits of the plastic into the towels.
    I cleaned out the debris and tried the machine on a short cycle while empty which worked perfectly.
    This morning the machine started to fill up as normal, then proceeded to leak out from underneath the machine. I switched off the machine and opened the door and noticed that the fill level had not appeared to reach the door seal.
    Reading some of the posts here I suspect the bearings & seals need to be replaced, but before i start i thought i would post the problem here to see if I am going in the right direction
    Any pointers or ideas to identify the issue before i get the spanners out would be gratefully appreciated
    Many Thanks
    Al
    #320553
    Re: Zanussi Jetsystem starting to fail
    The clonking is the drum bearings failing. The drum then runs cock-eyed and cuts through the plastic of the tub, hence the leak. You’ll need the bearing set, drum support spider, tub seal and the tub front half to repair it.
    I would suggest that it’s just not a cost-effective repair.
    BigAlly
    Thanks for detailing the how the failure occurred.
    With regards to the parts, how much am i looking at for the tub front half as the rest of the parts comes to about £70 ?
    #320555
    pNc number (the one that starts with 9), please.
    P45.
    #320556
    BigAlly
    the number is 91460141400
    Many thanks for you’re help
