Zanussi Jetsystem Turbodry 1200 (Model WJS 1265W)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Jetsystem Turbodry 1200 (Model WJS 1265W)
  • #22074
    cooking_fat
    When the above machine is set up for the required program, pressing the Start button results in 3 successive clicking noises and it then shows Error E40. The manual lists the error as being “Door Open”, but the door is definitely locked.
    Would be very grateful if anyone has any ideas about this.
    Many Thanks,
    Andy 😛
    #193595
    Re: Zanussi Jetsystem Turbodry 1200 (Model WJS 1265W)
    Door lock can still be faulty – it will initially lock on a solenoid, but still needs to energise the delay lock. There are five potential faults, one is the door lock – the other four are related to the control circuits and the computer. Complex machine – probably time to get some pro help. Click the link below for a UKW engineer in your area.
    Power off if you choose to investigate for yourself.
    cooking_fat
    Hi, Penguin45,
    Thanks for your help. You say the door lock can still be faulty. Can you tell me how I can check out if this is the faulty part? I’ve got a multimeter etc. If this is the faulty part I could probably change it myself. If not, then as you say, time for the the professionals. Any help greatly appreciated.
    Andy
    #193597
    bendaireboy
    as penguin has said this is a complex appliance,the interlock does some processes in conjunction with the elecronics so it is not alway’s possible just to meter it,it also has a diagnostic’s prog so an engineer is most probably your best bet and cheaper sorry
    #193598
    cooking_fat
    Thankyou both for your advice. Looks like a job for a professional.
    Andy
