zanussi keep pauseing
  • #57370
    agro
    hi guys got a l14710vit prod number 914601224,00 put the machine on fills up motor turns a couple off times and adds more water pressure switch clicks when full then goes straight to pause. machine spins fine ive noticed when it pauses i have to reset drains a little then pauses again weird faultand ideas
    #330957
    aqualectric
    Re: zanussi keep pauseing
    An earth leak on the drier element will cause odd faults like this – usually program abort issues early in the cycle.
    Disconnect the drier element and try it again. If the fault clears, change the drier element. This fault tends to be more prevalent on machines where the drier is little used. :rolls:
    Hope that helps,
    Steve.
    #330958
    agro
    didnt think to check that ive had a couple of these and all been washer dryers ill try it 2mw and post how i got on
    #330959
    agro
    excellent mate cheers worked
    ive also had one id written of been in the garden for 3 months tried it on that as well bet its a regular fault machinew now working in garden .One point however howd you find the fault yourself
    #330960
    allan73
    As Aqualectric say’s this is a common problem with Zan wd’s most often if dryer is little used.
    I think there are several posts on here regarding this.
    #330961
    agro
    flipping sod of a fault though .ill remember that one
