Hi there,
I have a lindo 300 ZWF01483WR. Recently the pump stated making a noise suggesting something had found its way in so I took it off and hay presto there was some bits of plastic from new cloths that had found their way in. I subsequently built it all back up however the assembly that connects onto the base of the drum is now leaking. I have had it off and on several times, I have totally cleaned the Machine pump body and have tried the bolts at several different torques and used vaseline and still it leaks. The strange thing is there are 4 bolts which hold the assembly onto the drum 1 is very rusty, 2 are rusty under the head of the bolt and 1 is totally rust free which could suggest it has been leaking for some time.
Any help or suggestions would be greatly appreceated.
Scott
