Zanussi Lindo 300 Model ZDC 8203WR Prod no 91609737700 bought 23/4/2018
Front panel indications are all normal, after selecting program etc dryer rotates as normal but after exactly 5 mins it stops. There is no heat at any time.
I have changed the element and the NTC sensor with no result.
Condenser and filter are both clean
You can only select the programs from the menu, you can’t set a specified length of time. i.e. when you select cottons you get 1hr 40 mins, which you cannot change. We have tried most of the programs and after exactly 5 mins it stops.
The way the snag first showed itself was when a load of wet clothes did not get hot.
had an AEG that did similar things and it ended up being a bad solder joint on the motor relay so motor would only go one way. When it reversed and did not run, the software ended the programme and because some machines hide the fault the owner sold it
