Zanussi Lindo300 Tumble dryer flashing red
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Lindo300 Tumble dryer flashing red
  • #94116
    grooster
    I’ve been out to a Zanussi tumble dryer this afternoon, ZDC8202P, Prod no. 916097379 00, and all that happens is the red start pause button flashes red as soon as you press it to start.
    If I go in to what I suspect is the diagnostic, similar way to the washing machines, (not had much practice on this machine yet), and press the programme button a few times, the start button flashes 11 times red and the yellow light 14 times.
    Is this a fault code?
    If anybody can help it would be appreciated.
    Nick
    #456490
    Re: Zanussi Lindo300 Tumble dryer flashing red
    have sent diagnostics to your inbox
    if the flashes are a fault code as you sat it does not make sense
    red flashes 11 puts first letter B (H on led machines)
    second digit 4 does not exist but all B fault codes as to do with supply problems and normally mean main board failure unless the supply is fault
    anyway see if it will run diagnostic cycle and check for stored codes and go from there
    grooster
    Cheers Dave, really appreciate your help.
    Nick
