Zanussi loud on high spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi loud on high spin
  • #11654
    djones
    I have a Zanussi FLA1201W that has started to make a loud noise when spinning on its fast setting. It is fine on the slower spin speed and the drum can be turned freely by hand with no noise when empty. I thought that it could be something stuck between the inner and outer drum parts?
    Any suggestions?
    Thanks, David
    #146150
    Re: Zanussi loud on high spin
    djones wrote: I thought that it could be something stuck between the inner and outer drum parts?
    Indeed it could be something caught between the inner and outer drum (coins etc) and I would recommend you get someone local in to have a look for you. Try our Repairs@ for further assistance.
    #146151
    I would like to give it a go myself as I am very handy with taking things apart and unlike many, can usually put them back together again! 😀
    Can you possibly recommend where/how to start looking? Failing that I will get someone out.
    Thanks.
    #146152
    Goatboy
    If it is a foreign body, it will be very hard to remove on a zanussi…
    …unless it’s down the front of the inner drum.
    Try looking down the tiny gap between the door seal and the inner drum.
