Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi module problem?
- This topic has 8 replies, 5 voices, and was last updated 17 years, 2 months ago by
Martin.
February 4, 2009 at 1:07 pm #43144
ParticipantI’ve got a ZJD1291 (washer-dryer) and the symptoms are that only the on/off switch and its light are working, no display, nothing – dead!
I’ve whipped the module out, it’s blown, and as far as I can establish the likely culprit is the door interlock? In as much as one of the 4 wires from the interlock go to the board where the connector and track have blown. Also part of the centre of the board has blown too. 😕
My question therefore is :
Do faulty door interlocks blow these boards as a rule? Has someone had the same fault and replaced both to cure the problem?
The reason for my diagnostic caution is that the job is 25 miles from base, the parts are very costly and combined labour/travelling cost will take up a good 3 more hours to sort – hence I need to be sure. Failing that tell her to scrap it (although it is just 17 months old 😯 )
Any advice much appreciated. 😀
February 4, 2009 at 1:26 pm #276190electrofix
ModeratorRe: Zanussi module problem?
are these machines not covered by a 5 year parts guarentee any more? they used to be
if it is put it zanns way and charge for your visit
dave
February 4, 2009 at 1:41 pm #276191Martin
ParticipantRe: Zanussi module problem?
electrofix wrote:are these machines not covered by a 5 year parts guarentee any more?
Not as far as I’m aware? 😕
February 4, 2009 at 1:55 pm #276192electrofix
rang lusx customer care 08705 727727
if machine is under 2 years
they will either go 50/50 on repair cost or give money off a new machinechoice is dependant on parts cost i think in this case will be money off new one but it must be their engineers who go out
February 4, 2009 at 2:11 pm #276193Martin
Cheers for that Dave, I’ve phoned my customer and she’s now going to ring them to get it sorted…cheers mate! 😀
Still would like to know if interlock failure causes these module to blow though? 😕
February 4, 2009 at 6:21 pm #276194Madmac
Is that the front mounted module in a grey plastic split housing?? if so, yep, interlock shorting often pops the board, solenoid interlocks on Zans seem pretty suspect generally.
February 5, 2009 at 11:36 am #276195Martin
Thanks for that reassurance at least. The module sits front top r/h/side in a white split plastic case in fact not grey. 🙂
February 5, 2009 at 9:13 pm #276196funkyboogy
seen a few of these interlock >>pcb,
also had pumps taking out the pcb.ally
February 6, 2009 at 9:14 am #276197cornwell40
Yup, and solenoid valves at 13 months 🙁 .
TC
