Zanussi Nexus FL1081 wash cycle dial loose
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Nexus FL1081 wash cycle dial loose
  • #68973
    Jackoverboard
    ZanussiNexus FL1081.
    Been given this machine that appears to be in working order but, the wash cycle dial moves round with the setting knob ie. the bit with ABCDEFH on it.
    Question, can anyone on this forum please tell me where it is supposed to be so that wife knows where to set knob for a particular wash, A,B, C, etc ?
    Thanks in advance for any help, first post here.
    #373319
    Seamy
    Re: Zanussi Nexus FL1081 wash cycle dial loose
    There should be a small hole in the front of the knob, push in a small pin or needle & turn the knob slightly anti clockwise, it should pop off towards you then, with this off you can see the inner piece which is more than likely broken, see which parts are required & serach on the shop here for required parts.
    #373320
    Jackoverboard
    Hi Seamy, thanks for reply. Not sure if I have explained the problem correctly. It is the label underneath with the wash programs letters on it that is loose. I nead to stick it down in the correct position or is it held in the correct place by some other means? Knowing where A,B etc should be, I was just going to glue it down.
    #373321
    Jackoverboard wrote:I was just going to glue it down.
    You will need first to remove the outer timer knob AND the inner timer knob(as Seamy referred to earlier) to enable you to to inspect the device (which is called a Cycle Indicator Part No: 1246491201).
    It could be the the two locking lugs have broken OR that the guide has broken OR that the Timer Cam Wheel has broken? Access to all these is less than simple in the grand scheme of things. And the use of glue a certain no no!
    HTH? 😀
    #373322
    Jackoverboard
    Hi Martin, thanks for your input. I obviously nead to understand how the “cycle indicator” and “wash timer cam wheel” is supposed to work. I thought it was just fixed in position to indicate where to set the timer knob for any type of wash. Not as simple as that then.
    Could you perhaps elaberate on their workings please
