zanussi No Frost ZK87/34EF no go
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi No Frost ZK87/34EF no go
  • #21571
    bubs
    HI,
    Had a zanussi No Frost ZK87/34EF (928405300) dead today.
    This is not a familiar model, the only life is from the comp cooling fan, internal light and the fast freeze button lights up if pressed.
    I was going to order a power pcb (guess!) but having looked at the circiut diagram am more confused. There is 3 pcbs? nct’s and an air stat?
    Any help from the Electrolux boys would be appreciated.
    Cheers
    Graeme
    #191360
    cab
    Re: zanussi No Frost ZK87/34EF no go
    Hi not had this problem before, I asume that the compressor isnt running? most probs with these are not defrosting hence no cold in fridge and only cool in freezer, check your private messages.
    cab
    #191361
    bubs
    Thanks, have done so.
    The compressor is not being started at all.
    It’s a complicated thing compared to the common
    VT9 + defrost timer models.
    Cheers
    Graeme
    #191362
    cab
    yep, glad you found manual on tds.
    cab
    #191363
    bubs
    Thanks Cab,
    In case someone else has the same problem,
    went back today. The machine is acting like it’s stuck in “dipslay” mode.
    All the buttons work but i can’t get into test mode. Quoted for a contol PCB, customer could not wait.
    Cheers
    Graeme
    #191364
    cab
    Hi graeme,
    have experienced probs with user control, Zanussi modified early ones, used to work for them 4-5 years ago. same S*** different day!!!
    cab
