ZWD1261W
Machine seems to do everything except spin. Every time it is put on spin including at the rinse part of programme it ramps up then just as it goes to whip into spin it cuts out the spin and trys to ramp again until end.
I’ve had a similar problem, with a Zanussi, I can’t be sure of the model number now, but a new module sorted the problem. The fault on your machine sounds identical. A quick call to EMW and Tony should be able to confirm that. Good luck. Graham
