Zanussi Oven – Cooling fan issue
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi Oven – Cooling fan issue
  • #95433
    adrianmstarling
    I have a zanussi ZOU370 double oven, electric top oven and fan assisted bottom oven.
    When using the top oven the cooling fan starts as soon as the oven is turned on (so I know the cooling fan works) but when using the bottom oven, the cooling fan never kicks in and as such generates moisture on the overhang of work surface above it
    Now from what I understand it won’t kick in until the outside oven cavity temperature reaches 110.
    Why is the cooling fan not kicking in when using the bottom oven ?
    Thanks in advance
    #460328
    https://shop.ukwhitegoods.co.uk/8996619267611-aeg-electrolux-oven-cooling-fan-control
    possibly the above part
    the wiring diagram seems to show the cooling fan being controlled directly by the top oven control but seems to be controlled by this part on then main oven. if this part is in use the fan should run on after the oven is turned off, if yours is not doing this then this part will probably fix it.
    be aware there is more then one cooker with your model and I have only looked up one at random so check your oven has this part fitted before proceeding
    adrianmstarling
    Just to say thank you for this, I ordered the part from yourselves and have replaced and now the oven is working as expected
    Thank you for your help
    Adrian
