Zanussi Oven Element and Thermostat Help !
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi Oven Element and Thermostat Help !
  • #64079
    captainfurious
    Hi there,
    I have inherited a Zanussi ZHF 470 Double Oven moving into my house. Shortly after arriving the fan oven stopped working so I checked the websites and worked out the element had gone – it was pretty obvious when I took off the housing! I replaced the element and oven was working straight away.
    6 months on the oven has stopped working again. I opened the element case and the element had once again gone – totally charred and broken. This new element only lasted 6 months and we don’t over work the oven. I have ordered a new element to replace it again but I’m wondering coupled with this there is another issue. My thoughts are either:-
    1. The thermostat has gone and this needs to be replaced. I have to say until breakage two the heat seemed to be fine.
    2. When putting in the element I am not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure I conected the two wires at the back correctly on each rod. I lost the wires through the back of the oven so when I pulled the whole thing out I may have connected it the wrong way round. If my memory is correct I think there is one blue one red…..is one top and one bottom or doesn’t matter?
    3. The only other thought is we didn’t exactly keep the oven overly clean. Could a build up of crusty food casue a problem.
    4. Its old….get a new oven!
    Any ideas is greatly appreciated!
    Cheers
    Rich
    #355984
    steve1
    Re: Zanussi Oven Element and Thermostat Help !
    hi
    is the fan motor working?
    if the motor is not working or running slow it will cause the fan element to overheat and burn out
    #355985
    captainfurious
    hi there,
    thanks for the response. the fan motor is not working at present. However last time the element went the fan didn’t work until I replaced the element. In fact, when I turn the oven on the light doesn’t even illuminate or start. This was the same last time until I replaced the element.
    Rich
    #355986
    captainfurious wrote:This was the same last time until I replaced the element.
    Replace the element again Rich then see how it goes. Elements are a very week point and don’t last long at all. 6 months out of one ain’t all bad especially if we are talking ‘non-genuine’ parts here? 😉
    #355987
    steve1
    HI
    THE FAN AND LIGHT SHOULD WORK even if the element has failed
    #355988
    captainfurious
    Hi there,
    Thanks for all the advice. Yes, the previous element was non genuine. I am sure the light and fan didn’t work last time it went….the fan certainly didn’t. I’ll change the element and see how I get on.
    Rich
