Zanussi Oven ZDQ995X continues to heat way beyond set temp
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Oven ZDQ995X continues to heat way beyond set temp
  • #84232
    Washdisher
    PNC 944171376
    This is a double oven with sensors instead of stats and the problem occurs on the fan with rear element setting.
    Both sensors were in region of 600 ohms ambient and both cables tested ok for continuity. Substituted top oven sensor for main oven sensor but did not cure the problem. Display board or main control board? Could not spot any damage to main control board but must admit I didn’t look at display board.
    Any help gratefully received.
    Dez
    #425138
    Seamy
    Re: Zanussi Oven ZDQ995X continues to heat way beyond set te
    Check elements, if earth fault on element it can cause this problem.
    Board could be faulty either.
    #425139
    Washdisher
    Hi Seamy,
    Thanks for that, I’ll recheck.
    Dez
    #425140
    Washdisher
    Turned out to be the power board. Replaced and all working fine.
