Hi all, does anyone have a wiring diagram for this ZOB range of single built-in ovens? I fitted a new grill to one a few days ago but the customer has phoned and said the cooling fan just stays on if the grill is used but ok with the oven? Hmm. It was a straight forward grill element replacement although the fan cut out stat is attached via one of the grill element support screws but it did not need disconnecting electrically . I’m just hoping the guy didn’t have a fiddle around with things before I got there 😕 Mike.
Well here is the wiring diagram, clear as mud for the most part, so I wish you well. 😕 I’m thinking though it might just a faulty red spot stat? 💡
