Zanussi PCB R93 resistor value
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi PCB R93 resistor value
  • #94406
    dunston
    Does anyone know the resistance value of R93 on a EWM2100 board.?
    The replacement board is part number 973914606027-00/6
    #457248
    Re: Zanussi PCB R93 resistor value
    have a few of that board round here but have nicked the resistors. that resistor serves 2 jobs
    1 it a surge resistor to limit the charging current of the main caps
    2 its a safety resistor which can blow if things go wrong
    I would use a 3watt 47 ohm fusible resistor which should fit the bill but if that resistor has blown I would also expect the power chip to be faulty also
    dunston
    Thanks Dave.
    The resistor has broken up that’s why i couldn’t read the value.
    Have you every changed the power chip? Do you mean the link switch?
    #457250
    done lots of them
    resistor can blow for various reasons but the power chip is most likely. resistor feeds the power through a diode to charge a capacitor to about 300 volts DC. if the diode or cap fail will also blow resistor as that is part of its job
